2000 seville ashtray removal
Old Jul 24, 2008 | 03:13 PM
chadmack's Avatar
Default 2000 seville ashtray removal
Was wondering if anyone could tell me how to remove the ashtray in the center console? I dropped a credit card behind the ashtray door and cant get to it....thanks
Old Jul 28, 2008 | 04:27 PM
SwampeastMike's Avatar
Default RE: 2000 seville ashtray removal
With console open and shifter in neutral insert something about the size of a "Sharpie" felt marker pen diagonally into one of the rear corners of the shifter trim plate until the clip releases. Repeat in other corners as necessary. Pull back and up, disconnect the traction control wiring at the switch with a small flat screwdriver, pull slightly over the shifter handle and disconnect the harness connector leading to the heated seat switches, then remove.
shotandabeer
Feb 11, 2008 09:56 PM
FlatLander
Dec 1, 2007 05:33 PM
misfit6794
Jan 9, 2007 02:45 PM
mcw
Jan 8, 2007 07:39 PM
fatboy
Jul 4, 2006 08:59 PM
