overheating prob
Old Jun 6, 2009 | 03:31 PM
llwta76's Avatar
Default overheating prob
Hi everybody! I own a 1988 Eldorado w/the 4.5 eng. The serp. belt let go ~ 1 mile from the freeway off ramp and had to hobble home. (about 4 mi. non-freeway mi.) Eng coolant indicator got to 273deg. for a brief time before I shut off. This happened 3 times before I finally made it home. This it a 4.5 engine and am asking for your thoughts as to whether I did any harm. Right now it's sitting in my drive cooling down. I really appreciate your thoughts! New member and Cadillac owner. Larry
Old Jun 6, 2009 | 09:00 PM
IF and IF your coolant remained in the system, at 273F, you should be OK. IF any boiled out of the filler cap, drain it tomorrow, and re-fill with 50/50 mix. If it is more than 5 years old, same thing.
GUYS/ GALS .. belts, hoses, after 5 yrs or 50,000 miles you are asking for it .. big time.
common .. $25 vs $1,000 ? Gambling at Vegas is more fun !
Also, gotta tell you, the tow truck is a lot cheaper than an engine .. do NOT drive it even 1/4 mile next time ..
next solution? PARK IT .. walk to the parts store, walk back, install belt, drive home.
Old Jun 9, 2009 | 11:11 AM
Dan_Seattle's Avatar
Default Overheating?
Water at 273 degrees probably should have been going by your radiator cap. 250 degrees is something like 15psig. If that ever happens again, I would pull over and let it cool down for 30-40 minutes, drive a mile or two, let it cool again.
Stealth is correct, $100 in belts and hoses isn't worth a $1000 engine. At first thought I would say 270 degrees plus would harm an aluminum blocked engine, but as long as it starts and sound good, you're probably okay.
Let us know how it turns out.
-Dan
Caddyman77
May 8, 2008 02:20 PM
KNUCKLEHEAD
Apr 12, 2007 07:50 PM
lido
Feb 7, 2006 01:08 AM
gsteward
Jul 5, 2005 01:49 PM
MacDuff
Sep 23, 2004 12:49 PM
