More Gas Burned in the Winter?
ORIGINAL: NAFTA
thanks a lot, since i warm up the car for like 2 minutes now and my avrg MPG were at high 8's , 9's its went up to 10's - 10.5's. lol its still bad but better, alrite for cold weather and all city driving i guess.
you did check the tire pressure. right?
you got a clean air filter? how about a K&N filter?
you arent running 50w oil, are you?
Where are you? in Upstate NY, it gets so cold that some trucks partially cover the radiator
to allow the engine to stay warmer while driving in freezing temps.
no, i'm in chicago. i think my tires may be a little under the pressure they are supposed to be at, then again i'm not sure what pressure they have to be at. can a WOT help anything if it hasn't been done before ?
ORIGINAL: NAFTA
how about the tire pressure? if they are lower than they're supposed to be how much more gas is it going to wase ? maybe like 1 - 2 more mpgs ?
Probably and additionally your tires will not last as long when under inflated.
Well thanks a lot for the replys, I just pumped my tires up today to 44-45 psi and I'm getting about 2 MPG maybe a little more. They were all different between 24-40 psi. The only bad thing is now that you feel more bumps and it doesn't ride as smooth, but definately helped my MPGs. Thanks
mosey
Dec 27, 2013 01:04 PM
vettelover91
May 7, 2012 01:29 AM
