northstar running hot
Old Feb 23, 2008 | 08:52 PM
grease_monkey1965's Avatar
Default northstar running hot
im looking into buying a 1999 sts but it is running hot im thinking it has a clogged radiator or a bad head gasket havent fulley checked out vehicle yet owner says it needs a new motor but seems to run too good for that owner is not a tech car starts first turn and runs like new any ideas thanks
Old Feb 24, 2008 | 08:04 AM
76eldoragtop's Avatar
Default RE: northstar running hot
Could be one of those or something as simple as a thermostat etc. etc. Pressure test.
You might get a steal on this one if the guy thinks it need a new motor, on the other hand I wouldn't jump at it without fully checking this problem out.
Good luck
Old Feb 24, 2008 | 08:41 AM
If you have the ability to do it yourself or deep pockets I would pursue it. Worst case it will need engine. Being its a 99 check to see if recall applies you will very lucky if it does.
http://www.cadillacforum.com/m_18624..._2/key_/tm.htm
Mags1
Nov 19, 2010 07:37 PM
needhelp
Nov 8, 2005 01:20 PM
needhelp
Jun 15, 2005 11:51 AM
needhelp
Dec 16, 2004 06:12 PM
