Loss of Electrical power
Old Jul 17, 2007 | 01:43 PM
mistrbbkp's Avatar
Default Loss of Electrical power
I have noticed that when I start the car (Eldorado 2000 ETC) that sometimes the trunk or fuel door will open and my clock inside seems to be loosing time. It seems that I also lose electrical power when I first turn the ignition. Does this sound like a battery issue or the altenator? Thanks for your help
Old Jul 17, 2007 | 02:51 PM
FLCaddytech's Avatar
Default RE: Loss of Electrical power
yes, that is a typical sign the the battery is near its end.
A loose connection or bad ground would do this to.
Check the pos terminal for acid leaks or corrosion also.
Old Jul 18, 2007 | 03:01 AM
ORIGINAL: mistrbbkp
I noticed recently that when I start the car (Eldorado 2000 ETC) the trunk or the fuel door pops open. I've also noticed a loss in electrical power when I turn the ignition. I am showing 13.9 - 13.0 volts. Any suggestions? Could it be the alternator?
please do not post the same thing over and over in different threads and then with variations of the problem.
nypromo
Jun 16, 2009 04:20 PM
JBlitzen
Nov 13, 2008 06:44 PM
globalvillager
Oct 5, 2008 05:18 PM
runtime
Apr 17, 2008 03:36 PM
mar322
May 30, 2007 05:11 PM
