Ignition Problem
Old Jan 26, 2008 | 02:08 PM
royalet's Avatar
Default Ignition Problem
2000 Caddy Deville DTS[:@], I am through with these cars, wnet outside to get in the car , placed the key in the ignition, ignition wont turn at all, looks as if something is broke when i look through the key hole, I can replace the ignition, but I cant get the ignition to turn to the on position so that I can release the lock release and pull the ignition switch out. Does anyone know how to get the lock cylinder out in this situation. Thanks
Old Jan 26, 2008 | 03:36 PM
Default RE: Ignition Problem
You will need to estimate where retaining pin is and drill housing. If you are too far off, you have to replace housing. You could play with key and hope it turns. Make sure key your using opens door.
Old Jan 27, 2008 | 02:29 PM
royalet's Avatar
Thanks, if i manage to get another ignition with a key with it, it should be plug an play right, nothing has to be programmed or anyyhing?
Old Jan 27, 2008 | 03:09 PM
Dont you have a VATS key ?
Old Jan 27, 2008 | 04:31 PM
royalet's Avatar
Yes I believe so, I did manage to contact a locksmith who said they could get the the ignition from the dealer, and come install it and program it to the car, I guess thats my best bet,
Old Jan 27, 2008 | 05:45 PM
ORIGINAL: royalet
Do you have AAA ?
They will pay for the 1st $100 if you have their towing service.
Old Jan 28, 2008 | 05:38 PM
royalet's Avatar
Problem resolved, purchase loch cylinder fro dealer for $125.00, cost $375 to be done by the locksmith
Old Jan 29, 2008 | 03:23 PM
royalet..... and you said "you were through with these cars"............ way to go royalot!!......patience,..... keep the faith!
rick
DavEldorado
Sep 22, 2013 07:40 PM
LOWRIDER60
Dec 26, 2010 01:37 PM
rmichaelhanna
Oct 5, 2010 07:14 PM
AIeradi
Aug 28, 2008 09:36 AM
