Ignition Problem
2000 Caddy Deville DTS[:@], I am through with these cars, wnet outside to get in the car , placed the key in the ignition, ignition wont turn at all, looks as if something is broke when i look through the key hole, I can replace the ignition, but I cant get the ignition to turn to the on position so that I can release the lock release and pull the ignition switch out. Does anyone know how to get the lock cylinder out in this situation. Thanks
RE: Ignition Problem
You will need to estimate where retaining pin is and drill housing. If you are too far off, you have to replace housing. You could play with key and hope it turns. Make sure key your using opens door.
Thanks, if i manage to get another ignition with a key with it, it should be plug an play right, nothing has to be programmed or anyyhing?
Dont you have a VATS key ? |
Yes I believe so, I did manage to contact a locksmith who said they could get the the ignition from the dealer, and come install it and program it to the car, I guess thats my best bet,
ORIGINAL: royalet Yes I believe so, I did manage to contact a locksmith who said they could get the the ignition from the dealer, and come install it and program it to the car, I guess thats my best bet, They will pay for the 1st $100 if you have their towing service. |
Problem resolved, purchase loch cylinder fro dealer for $125.00, cost $375 to be done by the locksmith
royalet..... and you said "you were through with these cars"............ way to go royalot!!......patience,..... keep the faith!
rick |
