idles hi on deceleration 4.5 eldo 1990
Old Sep 29, 2005 | 01:22 AM
gmburd's Avatar
Default idles hi on deceleration 4.5 eldo 1990
posted all my problems on an earlier post 1990 eldo 4.5 bad miss
Well, got the care to pass emmisions.
Problem originaly___ bad hall effect and 4 injectors below resistance that was acceptable.
Then I failed emissions and checked the egr tubes at base of intake and they were plugged. Cleaned them out and nox went down to new vehicle specs.
Only problem now is a fast idle on deceleration. Tps and isc reset and all within specs, but idle stays high (1400 rpm) cruising at 25 - 30 mph. Have to use brakes and at 5 mph, it shifts down hard and idle settles down to 750 rpm as it should. Any one had this problem??
thanks
Denny
Old Oct 5, 2005 | 04:34 PM
Patrick's Avatar
Administrator
Default RE: idles hi on deceleration 4.5 eldo 1990
is there an idle control that you could turn down at all? possibly on the throttle body?
sbrant01
Mar 17, 2015 10:42 AM
Ricklh
Jan 1, 2009 06:10 PM
9treseville
Jun 22, 2008 05:41 PM
10e
Feb 24, 2007 12:08 PM
rollinslow84
Feb 6, 2006 02:41 AM
