Idles high or low; trans? radiator?
Old Jan 31, 2007 | 07:12 PM
10e's Avatar
10e
Default Idles high or low; trans? radiator?
i have an '00 deville with 152,000 miles.sometimes when i try and start it it wont idle so i have to gas it for a little while then it will idle. but then sometimes it will idlehigh atlike 1000 rpm's and feels like its accelerating on its own. even while driving the rpm's only go down if i come to stop in drive but then when i put it in neutral the rpm's go up to like 1300. i dont know if its the cold weather or needing a new radiator or transmission. ireally have no idea. any help would be very much appreciated.
Old Feb 10, 2007 | 01:17 AM
Katzmans Caddy's Avatar
Default RE: Idles high or low; trans? radiator?
I don't think that the radiator or transmission is where to be starting to cure an erratic idle. Start looking at the traditional poor idle areas. Spark plugs and wires, coils and fuel. The car will idle higher in very cold weather. Here in Toronto it is -10 to -20 and mine would idle at about 800 to1000 in neutral right now until it warmed up then it would settle at about 650 in drive or about 800 in neutral I would say.
While a poor idle seems like an easy fix and it probably is it won't be cheap. A fuel filter is $25, plugs are $130, wires $240 a set, coils are $90,. Mine was idling rough and bouncing between 500 and 800 RPM. I started with plugs and fuel filter and it got better then thereally cold weather hitand it was backfiring and stumbling. Had one bad coil with rusted terminals and change the wires. Did all this over the course of 6 weeks or so. Now I can't keep the front tires from spinning.
Of course if you have a trusted mechanic take it to him and put it on the computer, that will isolate the problem for sure.
Old Feb 21, 2007 | 04:40 AM
brougham1's Avatar
Hey 10E: A lot of the time the map sensor is the problem with erratic idle. You could also be encountering a faulty ECM. When it comes to electronics the fix is usually not cheap....Caddies are fun aren't they????
Old Feb 24, 2007 | 05:37 AM
downwardspiral's Avatar
yeah, I had the same exact thing, I thought I was the only one that paid 240 for a set of damn wires
Old Feb 24, 2007 | 12:08 PM
Genuine GM parts! Tough to buy anything else for a Northstar.
deville2000
Jan 27, 2012 12:02 AM
Need4Camaro
Aug 3, 2011 08:14 PM
ddzc
Apr 5, 2010 04:20 AM
SLBeck
Nov 14, 2007 10:21 AM
rollinslow84
Feb 6, 2006 02:41 AM
