idles hi on deceleration 4.5 eldo 1990
posted all my problems on an earlier post 1990 eldo 4.5 bad miss Well, got the care to pass emmisions. Problem originaly___ bad hall effect and 4 injectors below resistance that was acceptable. Then I failed emissions and checked the egr tubes at base of intake and they were plugged. Cleaned them out and nox went down to new vehicle specs. Only problem now is a fast idle on deceleration. Tps and isc reset and all within specs, but idle stays high (1400 rpm) cruising at 25 - 30 mph. Have to use brakes and at 5 mph, it shifts down hard and idle settles down to 750 rpm as it should. Any one had this problem?? thanks Denny |
RE: idles hi on deceleration 4.5 eldo 1990
is there an idle control that you could turn down at all? possibly on the throttle body?
