Help...turn/brake light doesn't work with headlights on
Old Sep 12, 2007 | 01:09 PM
meyer13's Avatar
Default Help...turn/brake light doesn't work with headlights on
I have a 1995 Seville sts. When the headlights, or sentenial, is on..the passenger side turn lights and passenger rear brake light doesn't work. Sometimes will flash twice and then stop. The drivers side works okay and with the headlights off everything works fine. Bulbs look good....Stumped....would appreciate any help.
Old Sep 13, 2007 | 07:09 AM
_X_CaddyTech's Avatar
Default RE: Help...turn/brake light doesn't work with headlights on
check the sockets. i bet you have a bad socket.
Old Sep 14, 2007 | 01:20 AM
meyer13's Avatar
Thanks for the input....I didn't think about the sockets.. but they look okay....replaced the bulbs....all hazard lights work with the headlights on...it is just the passenger side turn lights and brake light that doesn't work with the headlights on....flashes fine with lights off and then turn the lights on and it flashes once and then stops. Do you think it could be the turn signal switch on the steering column?
Old Sep 15, 2007 | 07:30 PM
try wiggling the bulbs while it is meesing up to see if they start to work....i be you have a bad socket
ATrain
Dec 14, 2012 12:24 PM
special k
Mar 3, 2011 03:51 PM
JTM000
Oct 11, 2010 04:49 PM
Cadillac Allante 1987 to 1992 Phase I & II
Apr 14, 2009 09:36 AM
