Drivers heated seat doesn't work
Old Feb 12, 2011 | 04:39 PM
special k's Avatar
Default Drivers heated seat doesn't work
First time poster here.
My heated seat on the driver's side went out a few days ago. When I push the button I hear a click and the light on the dash works-high and low but no heat. Passenger side works fine. 2005 CTS. Any common things I can check out? Its been cold and I really miss my heated seats, please help!
Thanks,
Kevin
Old Feb 13, 2011 | 11:48 AM
Underdog's Avatar
There is a fuse in the Fuse Block under the left rear seat labeled "L FRT HTD SEAT MOD". (10 A) It controls the Left Front Heated Seat Module. You might want to check that fuse. If that fuse is still good you may have to break out a voltage tester or test light and see if there is power going to the seat heater. Almost everything on this car runs thru the computer and it may require the services of a skilled technician.
Old Mar 3, 2011 | 03:51 PM
itisian's Avatar
Well the click is normal, my CTS and my friend's Escalade do that when I turn on my heated seat. The wiring or fuse might be messed up, have someone look at it.
JTM000
Oct 11, 2010 04:49 PM
Cadillac Allante 1987 to 1992 Phase I & II
Apr 14, 2009 09:36 AM
meyer13
Sep 15, 2007 07:30 PM
cyberwolph
Mar 11, 2006 07:51 AM
