Headlamps and lights flicker
Old Nov 23, 2007 | 12:18 PM
MetroAgt6508's Avatar
Default Headlamps and lights flicker
On my 96 Eldorado, there is a noticable flickering of the headlights and dashboard lights. They seem to pulse at a rate of about 3-4 times per second, independant of engine RPM. The car otherwise runs and drives beautifully, and displays no other symptoms that I have noticed. I would suspect a possible alternator problem if change in RPM affected this. Could it be a problem with the voltage regulator, or whatever passes for one on these cars? Any suggestions would be greatly appreciated.
Old Nov 23, 2007 | 02:51 PM
spencerhcollins's Avatar
Default RE: Headlamps and lights flicker
I experienced this same thing about 6 months back on my '97 STS. Lights flickering all over and no noticeable change with rpm - after about a month of that the alternator died completely. Voltage regulator is built into alternator. I replaced it with an all new alternator (not remanufactured). No more flicker.
Old Nov 23, 2007 | 04:39 PM
Metro ..
that is the best looking ElDo avatar i've seen !
jae
Jan 23, 2010 05:29 PM
ot1
Jan 13, 2009 05:55 PM
haist82
Oct 14, 2007 01:16 AM
usry28
Aug 31, 2007 08:02 PM
lenny lincoln
Apr 17, 2007 09:17 PM
