Gear shift removal
Old Oct 10, 2007 | 12:01 PM
royalet's Avatar
Default Gear shift removal
I have a DTS and i wanted to convert the leather handle that i have to the woodgrain, I have the wood grain on its way, but i dont know how to remove the shifter? some say trun and lift, I dont know
Old Oct 10, 2007 | 05:53 PM
Default RE: Gear shift removal
To get old handle off there is a 1/2 long clip on the part of handle that faces dash. Pry it out with a small screw driver and lift handle off shaft. Install according to instructions. If installing factory style handle start clip in slot install handle on shaft push down firmly and press clip in till flush. Hope it helps
Old Oct 11, 2007 | 09:29 AM
royalet's Avatar
Is this clip under the chrome piece or in between the wood and the chrome
Old Oct 11, 2007 | 09:49 AM
royalet's Avatar
Actually I got it off, the DTS doesnt have a clip, you have to twist the handle from right to left not to hard , just as if your wiggling it but use some pressure, and at the same time pull up, and it will release from the shaft. Good luck
Old Dec 18, 2013 | 06:37 AM
anash3's Avatar
Default Gear shift know
I have basically the same question
I wish to replace the shift know on my 97 Eldorado with the high polish wood type
How do I get the old Leather covered one off?
Macko11586
Jun 16, 2009 10:40 AM
quasi
Feb 11, 2008 08:52 AM
quasi
Jan 30, 2008 08:40 AM
97deville
Apr 11, 2007 12:53 PM
simjack
Jan 9, 2005 10:04 AM
