Fuel System
Old Mar 25, 2009 | 12:14 AM
Geezi's Avatar
Default Fuel System
I have a 92 seville with a 4.9 v8 that will turn over but not start it only stays on if you poor gas in under the hood I have change out the fuel filter fuel pump and fuel pressure regulator also check fuel injection lines and fuses not sure if there is a relay or computer that went bad any help is appreciated:confused :
Old Mar 25, 2009 | 07:25 PM
Codes? New or used fuel pump? What is fuel pressure requires fuel pressure gauge you maybe able rent/borrow or have to buy. Will noid light, when plugged in to injector connector, blink?(another rent/borrow/buy tool)
Old Mar 27, 2009 | 10:21 AM
Geezi's Avatar
the fuel pump is brand new no codes will check other and let you know
Old Mar 27, 2009 | 04:55 PM
ya got to figure your not getting fuel.....da..... have you checked fuel lines from back to front? good luck and welcome to the forum.....
Old Mar 28, 2009 | 11:10 AM
Geezi's Avatar
yeah i checked injectors under the hood and lines gas was flowing through after i changed out all new parts unless that was some excess fuel trapped in the line but i will check it out again any other suggestions are welcome thanks for all your help
Old Mar 28, 2009 | 07:58 PM
im goin to ask slowroll if he would jump back in here, maybe he has something to add. im at a lose at this point....sorry
Old Mar 28, 2009 | 09:14 PM
What is fuel pressure? Does noid light blinks?
May 14, 2011 12:04 PM
moneymark25
Aug 6, 2009 08:42 AM
Feuerhose
Apr 21, 2008 10:41 PM
jxer00
Oct 11, 2007 02:01 PM
peace707
Dec 7, 2006 02:05 AM
