Problems with fuel system
Old Oct 26, 2007 | 12:09 PM
Feuerhose's Avatar
Default Problems with fuel system
Car: Cadillac Seville STS 1992 4.9L
[hr]
Problem: When the Fuelgauge reaches the one quarter line, it stopps there and doesn't go any further. At this point there are still 6 gallons (22 liter)in the tank. when the fuel runs out, no warning appears, as it should. I know that an earlier owner had to replace the fuel pump.
I tried to remove the rear seats, because I guess the pump is under it, but i couldn't.
thanks for the help
Old Oct 26, 2007 | 05:17 PM
brougham1's Avatar
Default RE: Problems with fuel system
Probably just a problem with the sender unit. You could use your trip odometer to guage your fuel usage, or get at the pump/sender.
Old Oct 26, 2007 | 08:12 PM
couldn't that sender be had,by going at itin the front part of trunk floor? if there is a 4,5 inch enclosed hole there. open that and see whats up..... imo,
Old Oct 27, 2007 | 10:08 AM
You will have to pull tank to get to it, access plates did not come until 1998 redesign . Make sure tank is still flat or bowed down in center. Sometimes they will be bowed up and gas will in it,but away from pick up. When this happens gas gauge wont read empty, but you will be out of gas.
Old Apr 21, 2008 | 10:41 PM
ruaskier2's Avatar
FYI.... At a quarter of a tank on the instrument gauge, The tank would need to be severly dented...Not likely or else very noticable. I suspect, if the Pump was serviced, you'll have to get inside it, to find the answer. BEFORE doing so, you can unplug the wire harness, may have to lower tank, andapply a variable resistance to the open leads on the unplugged harness from 0-90 ohms, and check the instrument gauge functionality. If you get Full to Empty on the instrument gauge, then you know the Fuel Level Sensor either has a Bent Float Arm or wiper fingers could be damaged from previous owner.
May 14, 2011 12:04 PM
moneymark25
Aug 6, 2009 08:42 AM
jasmiceat
Jan 1, 2008 10:34 AM
jxer00
Oct 11, 2007 02:01 PM
peace707
Dec 7, 2006 02:05 AM
