Engine swap trouble
Hello everyone. I had a questionI hopesomeone out there could help me with. I have a 87' Fleetwood Brougham that had a Olds 307 in it from the factory. After I pulled the 307 outtoday, I went to install a 94' chevy 350 engine in it I aquired from a chevy van. The motor bolts up to the bellhousing of the 200-4r tranny with no problems, but it seems that the engine brackets of the 350 engine are to big. The motor sits high, only the passenger motor mount bolts up to the frame mountand there is a huge amount of space between the cross member and the oil pan. It seems that I'll need a different set of OEM motorbrackets ,but I have the slighest clue from which vehicle i'll need them from. Is there is anyone out there who can shed some light on this matter?
Thanks in advance
Ronson
Thanks in advance
Ronson
