4.9L trouble starting engine after rebuild
Old Oct 17, 2009 | 06:25 PM
blair15951's Avatar
Default 4.9L trouble starting engine after rebuild
I have a 1992 seville
I recently stripped the engine down, replaced all gaskets and seals and put it back together but now im having trouble starting it.
when i try to start it, it turns over for a second, sputters, then stalls
if i move the timing up, it revs to 3500 rpm and stays there.. even with the butterfly valves closed... i can slowly push on the accelerator and it will redline but if i push it hard the revs die down and then it stalls....
after each attempt, i have to turn the key back and forth so it primes and then it will do the same thing if i try to start it again
any ideas?
true2blue92
May 29, 2016 03:18 PM
Eddie012960
May 16, 2010 11:26 PM
blair15951
Nov 4, 2009 08:05 PM
caddybob
Oct 28, 2007 11:04 AM
PIMPDADDYCADDY
Aug 2, 2007 11:48 AM
