Engine Rebuild for 1968 Coupe DeVille
Old Aug 2, 2007 | 12:26 AM
PIMPDADDYCADDY's Avatar
Default Engine Rebuild for 1968 Coupe DeVille
HI EVERYONE I HAVE A 68 COUPE DEVILLE THAT I'M FIXIN UP TO BE REAL NICE I ALREADY HAD THE BODY WORK DONE/HAD IT PAINTED/ INTERIOR AND NEW CONVERTABLE TOP. THERE IS SOME LITTLE PROBLEMS WITH THE ENGINE IT JUST DOESN'T SEEM TO RUN AS SOLID AS IT USED TO AND THERE ARE SOME TICKING AND NOISES AND SUCH. WHAT I WOULD REALLY LIKE TO DO IS HAVE THE WHOLE ENGINE REMOVED AND REBUILTPAINT THE ENGINE COMPARTMENT AND PUT EVERYTRHING BACK IN NICE AND NEAT WITH NEW WIRES ALTERNATOR DISTRIBUTOR ETC. HAS ANYBODY DONE THIS? IF SO WHAT ENGINE PARTS DO YOU RECOMEND FOR THE ACTUAL ENGINE REBUILD?
I'VE ALREADY BOUGHT AND INSTALLED AN EDELBROCK INTAKE MANIFOLD/ EDELBROCK ELECTRICCARB 750 CFM/ K&N AIR FILTER AND CHROME.I'M LOOKING TO MAKE THIS THNG SHINE FROM INSIDE OUT ANY TIPS ON WHAT KIND OF ENGINE PARTS TOUSETO REMOVING ANDPUTING EVERYTHING BACK IN WOULD BEGREATLY APPRECIATED.
BRIAN
HERES A PIC OF MY BABY!
[IMG]local://upfiles/2720/88B9A8B9F94049BABF8428FB24F28D5D.jpg[/IMG]
Old Aug 2, 2007 | 10:57 AM
brougham1's Avatar
Default RE: Engine Rebuild for 1968 Coupe DeVille
Hey Pimpdaddy: Quite a pimpmobile you have there with a real pimpin' colour. Try and check out www.usapartssupply.com they have the factory rebuilt engines and appropriate parts as well. I think you have the 472 (7.7) which is about 375 hp you might be able to crank that up a bit with you new carb setup. You might even be able to put in a high perf. ignition system. Happy hunting.
Old Aug 2, 2007 | 11:48 AM
Katz ... this one is right up your alley.
PDC,
my suggestion?
get a ton of blankets and make sure you cover the fenders anytime the hood is open.
it will save that paint job.
also, post a bigger picture. you left me starving with that snack size pic.
robparker1111
Vintage & Classic Cadillacs
19
Sep 20, 2014 08:06 PM
jayg1972
May 14, 2010 04:32 PM
ta2ddaddy
May 30, 2009 02:06 PM
ta2ddaddy
May 30, 2009 11:11 AM
caddybob
Oct 28, 2007 11:04 AM
