1968 coupe deville trans leak
Old May 28, 2009 | 12:06 AM
ta2ddaddy's Avatar
Angry 1968 coupe deville trans leak
I have a 1968 coupe deville, and i have a REALLY bad tranny leak. I recently bought the car and didn't realize at the time that there was a tranny leak that was this bad. No biggy I got a good deal. But since the leak has gotten worse it seems to be slipping a lot more. I took it in to the local shop that specializes in classic cars and had them look at it. And they think a tranny service should fix the problem, I was hoping that someone could give me advice on looking into a new tranny or rebuilding this one, or just do the service and see what happens. Oh they are charging 800 for the tranny service and replacement of pinion bearing. Hope i am not getting ripped off to bad.
Old May 29, 2009 | 12:03 AM
ActionJackson4205's Avatar
Before spending the money, do you know the source of the leak? If it's just a seal or gasket that is leaking it could cost quite a bit less. As far as the slipping goes it's hard to say. If you have driven it alot with very low fluid that could be bad. If not too much driving it may be ok but no promises. If you were to warm it up and fill it to the appropriate fluid level does it still slip? I have a 70 coupe deville so I can give you a good idea at what your looking at. Get as much info as you can and we can see whats up.
Old May 29, 2009 | 07:52 AM
Evil_SpeedRacer's Avatar
If you do decide to go with the service at the shop, please PLEASE be sure to ask them how they do that. If they use the exchange system, tell them to kick rocks. You don't want transmission AIDZ in your car from the last car/s they had hooked up to it.
Old May 29, 2009 | 11:24 AM
get second opinion!!!! sounds like gasket, and or seals..... easy fix with a tranny service.... car should have had one by now anyway.
Old May 29, 2009 | 09:28 PM
ta2ddaddy's Avatar
Well I had them do a tranny service only, and the think that will fix the problem since the leak was att the very far back seal (near drive shaft) so a tranny servie was done and the discovered the u joints were shot also, I guess thats to be expected with a 40 year old car, and before you say it, I did personally go down and see the u-joints that were worn out to make sure they were really worn out and they werent trying to take my money.
Old May 30, 2009 | 09:04 AM
cool..... lol.. glad to see your on top of things taddaddy.... or under things...LOL
good luck with the issue. hope ya the best
Old May 30, 2009 | 11:11 AM
$800 ? Holy S * * *
Are they using holy sacred cow oil?
Before anything at all, add ONE BOTTLE of LUCAS trans fix, drive 100+ miles.
go home, then :
Drop the pan, fluid come out, change the filter, new gasket, TORQUE BOLTS, add 2 bottles of LUCAS Trans Fix (YES, AGAIN), fill system with proper fluid.. GO Cruise .. clock 100+ miles and report back ...
robparker1111
Vintage & Classic Cadillacs
19
Sep 20, 2014 08:06 PM
jayg1972
May 14, 2010 04:32 PM
ta2ddaddy
May 30, 2009 02:06 PM
PIMPDADDYCADDY
Aug 2, 2007 11:48 AM
lempoz
Dec 12, 2006 06:25 PM
