Engine cuts out
Old Dec 2, 2007 | 07:11 AM
SkyKing's Avatar
Default Engine cuts out
[:@] I have an "87" Coupe de ville, 100,000 miles. In the las t2 days the engine will cut out while driving and it is only the engine that is cutting out. The dash is still lit up like nothing is wrong. Digital read-out is showing speed,ododmeter is still readingm fuel in tank etc. Engine warning light never comes on. The only way the driver knows what happened is the power steering gets stiff and the gas pedal isn't responding. Car will restart while letting it coast. Engine doesn't sputter, no rough idle, etc. I'm thinking electrical. Where should I begin to look. Ignition switch or computer or ....
Thanks
Old Dec 2, 2007 | 07:57 AM
76eldoragtop's Avatar
Default RE: Engine cuts out
It appears that someone responded to your same question in off topic. Check it out.
Old Dec 2, 2007 | 10:18 AM
Check for codes and post E codes. Check grounds near alternator.Check fuel pressure 9-13 psi and holds when engine is turned off for atleast 1 min. Check for spark with tester. If no codes are stored, fuel pressure is ok, and ignition passes spark tester I would suspect ignition module.
Old Dec 2, 2007 | 11:14 AM
continued here:
https://www.cadillacforum.com/m_16047/tm.htm
GORDFAIRFIELD
Feb 16, 2015 10:14 PM
SkyKing
Dec 7, 2007 07:17 PM
trakspeed
Aug 31, 2007 08:01 PM
Lac DTS
Oct 11, 2006 10:50 AM
