93 sedan deville issues
Old May 1, 2012 | 04:29 PM
lineside522's Avatar
Default 93 sedan deville issues
Have a 93 sedan deville 4.9 with a few problems.
1. Put transmission in drive and it does not pull right. Like is in between 2 gears. If u drop it in low it takes off fine.
2. When u shut the trunk the pulldown motor will not activate to pull trunk down. Took motor off and tested on bench and it works fine both up and down. Tested the switches at trunk and they seem ok. Have 12v at each switch
3. Ac controls will not send 12v to the compressor. Can jump 12v to compressor and it will run ok. Checked high and low pressure switch ok.
any input would be greatly appreciated
thx
Grant A. Van Vranken
Oct 26, 2013 06:21 PM
kingsmanname
Jun 2, 2011 05:33 PM
abaines12345
Jun 8, 2008 11:02 PM
The Dan
Jul 26, 2007 03:56 PM
Occitiger
Feb 24, 2007 03:31 AM
