2016 SRX battery suddenly dead.
Old Oct 15, 2020 | 12:45 PM
Cadillac Bill's Avatar
Default 2016 SRX battery suddenly dead.
Have had my 2016 SRX and recently battery went completely dead with no warning. I have had battery problems in other cars. You get a warning? Some light on the dash?
I see the red battery symbol comes on along with all the other lights and goes off as well. I checked the battery and it shows, on my multimeter, that it is dead.
I put in another battery and it seems fine.
Do these batteries just suddenly die? No warning?
Any ideas?
Bill
Old Oct 19, 2020 | 01:53 PM
dtcassist's Avatar
Former Sponsor
No, the batteries usually don't just discharge themselves without warning, or at least some slow cranking.
Most likely you had something drain the battery after turning it off. First checks are any adapters or chargers plugged in to power outlets and USB ports, then making sure a dome light or other light didn't get left on. Short of these, it's possible a malfunction caused a control module or component to stay on incorrectly. If it happens again it may take some electrical diagnostic to trace down where the problem lies.
Old Oct 19, 2020 | 04:08 PM
Not sure. The battery is 4 years old. I put in a fresh battery and it works fine. I will check the codes in a few days. Did not know that there was a "Procedure". Now my cruise control does not work. Possibly other things.
Old Dec 31, 2024 | 07:49 AM
Bilgod's Avatar
Default Same problem/ battery drain
Any ideas?
Bill
Same problem. I pulled all the fuses one by one, still couldn't find whatever is causing the current draw... any suggesting for the next step will be helpful..--BJR
t57
Mar 18, 2020 01:40 PM
wildman2
Jun 6, 2018 05:52 AM
borderblossom
Dec 14, 2017 07:21 PM
Gene Hamilton
Apr 24, 2008 09:50 PM
ponch
Mar 20, 2007 04:12 PM
