Battery goes flat!
Old Apr 8, 2008 | 09:28 AM
Gene Hamilton's Avatar
Default Battery goes flat!
98 DeVille. Onshut down, everything turns off, as far as I can tell. Yet, on occasion, I find the battery completely discharged and am unable to start until battery charger brings it up again.
Cadillac service can find no reason for it. Alternator replaced short time ago as was Battery. This has happened 4 times recently. ?????? Everyone is at a loss as to cause ????? Any suggestions? Gene Hamilton -- Indianapolis, IN
Old Apr 12, 2008 | 12:02 AM
Katzmans Caddy's Avatar
Default RE: Battery goes flat!
Make sure the trunk light is operating properly, which means turning off when the trunk is closed. Simple, but make sure battery connections are clean and tight.
Old Apr 22, 2008 | 09:33 PM
Finally CUT the wire to the trunk light to make SURE it was unlit. Battery still discharged and had to have a 2-hour battery charger lift again. The battery voltage was down to 10.1 volts. ???????? gene hamilton[]
Old Apr 22, 2008 | 10:11 PM
How old is the battery?
Old Apr 23, 2008 | 01:24 AM
jerrymac's Avatar
Well, here is what I do to test for a battery discharge while the vehicle is sitting and not running. Remove the negative battery cable and hook a test light between the cable and the battery post. If there is any "draw" on the battery, the test light will light, although it will be very dim for a minor draw, and very bright for a significant draw. If the test light glows even dimly, you have a draw on the battery. just watch the test light and remove all of the fuses 1 at a time till the test light goes out. If the light goes out when you remove a certain fuse, than you will know that the draw is in thatcircuit. This will help you to narrow down the circut that is causing the draw.
Old Apr 23, 2008 | 10:55 PM
eothrash's Avatar
try the cig-lighter socket maybe loose
Old Apr 24, 2008 | 09:50 PM
Yes good idea and cell phone chargers are notorious for drawing down the battery, always make sure it is disconnected when car is not running.
stormychic
Apr 3, 2010 08:58 AM
420Deville
Oct 30, 2008 12:20 PM
shrekmobile
Aug 2, 2008 02:56 PM
Apr 26, 2007 03:30 PM
cowboycad
Nov 29, 2006 04:35 PM
