2002 Deville Oil Level
Old Apr 26, 2010 | 03:14 PM
tonedub's Avatar
Default 2002 Deville Oil Level
Whenever I start my deville, on the on-screen dashboard the "Check Oil" light flashes on. I checked the "info" on the dash and my oil level reads 78% and the trans fluid reads 100% What could cause this to come up? How can I clear it?
Old Apr 26, 2010 | 04:48 PM
2001_Seville_SLS's Avatar
Default Check Oil at Dipstick
If the check oil light is on you should check the oil level at the dipstick. The 78% indication in the dash refers to the recommended life of the engine oil not the level of the oil. Do not drive the vehicle when it is low on oil. It is good to get in the habit of checking the oil when you fill up so that you can find a leak when it happens and before it causes damage.
Adding oil to the proper level should clear the light.
I recommend changing oil by the odometer reading rather than the dashboard indicator because it is better for the engine. My Seville generally reads 45% to 50% oil life at 5000 miles.
jmoshier
Feb 23, 2009 05:14 PM
hd0642
Aluminum Block V8s
Aug 10, 2008 11:12 AM
fireman_103
Jan 31, 2008 08:11 PM
gyalteaser
Jan 30, 2008 07:00 PM
AaronJP
Jul 11, 2007 06:52 PM
