1999 Deville Water level
Hi to all, I am a proud new owner of a 1999 Deville. It seems to run fine but I am wondering about the water level. It was low when I checked it the other day while driving around town. I added some water to it. Cecked it yester day and looked a little low. What do I need to buy to do a exhaust fume test in the radiator. What type of coolant should I be using. I do not smell any antifreeze nor have I noticed any water on ground after parking. I had a friend pull the vin number and he said mine does not fall in the range with the Head Gasket problems.
ORIGINAL: fireman_103
There is a range of engines that are affected and a range that is not?
There was a recall 99086 involving 1999 Northstar and Aurora V8 for head bolt holes being drilled to deep. A condition where head bolts could come loose. There is a vin break of less than 20k cars to be inspected. Engines that failed inspection were to be replaced. VIN breakpoints:
DeVille XU791675 - XU802142
Seville XU938976 - XU940640
Eldorado XU613134 - XU614972
Only some of the engines would fail inspection.
ORIGINAL: slowroll
this is great information to have .. upon purchasing a car and to check if the recall was done it.
Add to FAQ section ...
montrose2914
Apr 13, 2012 05:32 AM
