2000 Deville E Brake STUCK! Please help!
Old Jul 23, 2007 | 06:43 PM
jakemoore83's Avatar
Default 2000 Deville E Brake STUCK! Please help!
problem solved
Old Jul 23, 2007 | 07:23 PM
FLCaddytech's Avatar
Default RE: 2000 Deville E Brake STUCK! Please help!
Silly question.
Did you try to start the engine and put it in drive?
If that doesn't work there is a manual release at the pedal mechanism.
Becareful! if you pushed it to the floor it will require a good bit of force to release it.
Sometimes putting it in neutral will help if the car is loaded up against the parking pawl.
Old Jul 24, 2007 | 12:35 AM
Thank you for the reply, I ended up taking the wheels off and pounding the spring out on the calibers, It seems to be fine now.
Jed Oettinger
Nov 18, 2014 07:48 PM
Sonata
Mar 14, 2011 01:25 PM
ANGONA24
Aug 19, 2010 09:59 AM
parlain44
Automatic Transmissions
Jan 22, 2009 12:58 PM
parlain44
Nov 10, 2008 12:06 PM
