2000 Deville E Brake STUCK! Please help!
problem solved
RE: 2000 Deville E Brake STUCK! Please help!
Silly question.
Did you try to start the engine and put it in drive? If that doesn't work there is a manual release at the pedal mechanism. Becareful! if you pushed it to the floor it will require a good bit of force to release it. Sometimes putting it in neutral will help if the car is loaded up against the parking pawl. |
Thank you for the reply, I ended up taking the wheels off and pounding the spring out on the calibers, It seems to be fine now.
