1971 Eldorado - combination valve problem?
Old Aug 15, 2009 | 11:57 PM
dror's Avatar
Default 1971 Eldorado - combination valve problem?
After the brake warning light went on, the braking system has been serviced. The mechanic found one of the rear brake cylinder leaking and replaced it. The braking system was bled off and checked on a special device that checks braking power of each wheel separately and found working perfectly.
However, the warning light won't go off. Can it be a combination valve problem? when i remove the connector from it, the light goes off.
Should it be replaced or can it be reset somehow?
Thanks.
Keys85
Apr 2, 2015 01:54 AM
orangecountycruiser
Jun 13, 2011 01:31 PM
dror
Sep 10, 2009 09:37 AM
drorso
Jan 19, 2009 09:21 PM
