1964 Cadillac Coupe DeVille motor swap
Old Apr 27, 2014 | 09:46 PM
Anthonycocacola's Avatar
Default 1964 Cadillac Coupe DeVille motor swap
I have a 1964 Cadillac Coupe DeVille with a 429, the motor has done nothing but given me problems, I'm about to pull it and go with a chevy 350 I purchased today. My questions are:
Will my existing tranny bolt up to the 350?
Can I purchase pre fabed motor mounts for the 350?
Has anyone ever done this swap?
Thanks for the help guys
Old Apr 28, 2014 | 01:50 PM
You will need different trans or adapter. Chevy has it's own bell housing bolt pattern. Trans-Dapt probably made a kit years ago, they still make trans adapter. Frame and motor mounts for a 64 impala may work. Your car should have BOPK Turbo 400. I would try to find a chevy Turbo 400 trans that should minimize extra fab work. I would install transmission first if using thm 400, bolt engine to it , and then layout mounts and brackets for engine. If using different trans you will have some additional fab work to do. I have never done this application, but its a small engine in a big engine compartment. It should not be too bad. You might want a welder available to help with fab work. Good Luck
Old Sep 24, 2021 | 05:43 AM
retrovet's Avatar
Default Retrovet
hi did you receive any reply’s on the swap I’m considering doing the same thanks
DanielAndrew
Jul 22, 2020 03:26 AM
blockbeeda
May 6, 2010 12:10 PM
blockbeeda
Mar 25, 2010 03:53 AM
davidrempel9966
Aluminum Block V8s
Mar 17, 2009 08:11 AM
Caddy87
Oct 31, 2007 07:47 PM
