Cadillac XTS The new flagship brings more luxury, power and fuel economy to the Cadillac brand.
Break Assist Warning
Old 10-13-2018, 03:41 PM
BK_Kaddy's Avatar
Default Break Assist Warning
I have a 16’ XTS with around 36,000 miles and have I have been to the dealership 4-5 times because of the Break Assist warning that keeps popping up. They tell me it’s fixed and give me the car back then a day or two later it pops up again. I didn’t see or hear about any recalls on this issue. Perhaps someone else has experienced this and if so, how was it fixed?
Old 01-20-2020, 02:32 PM
bcpape's Avatar
It's possible that you have an ABS sensor ring that has a slight crack in it. It may not be enough to throw a constant code, but may be enough to "flicker". Ask them if the code comes from a specific wheel. Problem is, they would have to pull the hub bearing to know for sure.
The sensor ring sits on the outer face of the hub bearing. It's a very poor design because after a few years, the corrosion gets behind it and starts to de-laminate and will crack it and in my case, break it right off. Mine even took out my sensor. That threw a constant code and also produced a "SERVICE TRACTION CONTROL" code. Once I changed both the hub bearing and sensor, all was well. Hope that helps.
nitinbud
01-25-2020 08:40 AM
Msoldner
08-03-2017 10:54 PM
khanawalt
06-20-2009 11:17 AM
lakeshore_96cadillac
07-19-2008 03:04 PM
cadilassie
08-29-2007 03:04 AM
Quick Reply: Break Assist Warning
