aftermarket audio system
Old Mar 11, 2008 | 06:22 PM
KrownEM379's Avatar
Default aftermarket audio system
I want to install a system in my car but i herd that i might have a problem with the stock bose system in my 94 sts. Do i have to rewired all the speakers seperately or is there a easier way? any help would be appreaciate
Old Mar 18, 2008 | 03:21 PM
GimmeTheGold's Avatar
Default RE: aftermarket audio system
Bose Speakers have different ohm's than aftermarket head units. Need different speakers probably.
Old Mar 18, 2008 | 11:02 PM
BOSE speakers carry their own amps within each speaker enclosure and
the main unit is a pre-amp.. other audio systems do not and the amp is in
the main unit.
once you understand that, you know what needs doing for what you want.
IF you change out the BOSE, it is likely that your rear BOSE also fit other cars
and are worth some change.
FYI - Allante (1987 - 1992) guys are always looking for replacements and I beleive
they may be 99% identical (except for a couple of mounting tabs).
- dont quote this as expert advice .. but as a possibility -
allciuyt
Jun 30, 2011 03:17 AM
steveoa1
Jan 9, 2010 05:45 PM
ajax68960
12
May 22, 2008 12:10 PM
psuperstar
Mar 18, 2008 09:32 PM
turbom
Jun 28, 2006 10:31 PM
