in dash aftermarket audio
Old Feb 24, 2008 | 09:09 PM
psuperstar's Avatar
Default in dash aftermarket audio
Is it possible to install an indash 7" dvd cd player in a 2000 cadillac seville sls. Some sites says it is possible and others say it isnt possible. If not ,what is causing the obstruction. If i cant get the indash then maybe i can install the one where the screen comes out from a single head unit. Any ideas or has anyone done this ? thank you
Old Feb 24, 2008 | 09:29 PM
NAFTA's Avatar
Default RE: in dash aftermarket audio
I'm doing mine tomorow. I'll tell you if you can put a DDIN in there or just a single. I have an eldorado but it's all the same. I think you should be able too since i seen eldorados with navigation/dvd, you might have a problem with the stock amplifier in the back though.
Old Mar 18, 2008 | 03:23 PM
GimmeTheGold's Avatar
probably need a single din unless you want to do some cutting(Dangerous!!) IF you lkhave bose, there will be other issueas as well
Old Mar 18, 2008 | 09:32 PM
NAFTA's Avatar
very serious issues, you're going to have to run new wires to all the places where the speakers are and install new speakers as well unless if the headunit you're getting is going to be BOSE like the stock speakers. otherwise you basically have to change EVERYTHING in the audio.
youngmoney89
May 16, 2009 11:29 PM
KrownEM379
Mar 18, 2008 11:02 PM
LGT Automotive.com
Aug 25, 2005 03:20 PM
LGT Automotive.com
Aug 25, 2005 03:11 PM
RimAuction
Apr 23, 2005 01:55 PM
