aftermarket audio system
I want to install a system in my car but i herd that i might have a problem with the stock bose system in my 94 sts. Do i have to rewired all the speakers seperately or is there a easier way? any help would be appreaciate
RE: aftermarket audio system
Bose Speakers have different ohm's than aftermarket head units. Need different speakers probably.
BOSE speakers carry their own amps within each speaker enclosure and
the main unit is a pre-amp.. other audio systems do not and the amp is in the main unit. once you understand that, you know what needs doing for what you want. IF you change out the BOSE, it is likely that your rear BOSE also fit other cars and are worth some change. FYI - Allante (1987 - 1992) guys are always looking for replacements and I beleive they may be 99% identical (except for a couple of mounting tabs). - dont quote this as expert advice .. but as a possibility - |
