ABS problem
Old Mar 2, 2011 | 08:12 PM
99 sls's Avatar
Default ABS problem
Hi, having ABS/stability/traction problems with my 99 SLS. Codes are C1242, C1243. From what I've been reading, bad ground connections are the first place to look especially at g100 & g102. Where are these ground connections located? thanks
Old Mar 2, 2011 | 09:24 PM
other than the battery grounds, you need a manual to find them all ..
Old Mar 6, 2011 | 02:59 PM
gmtechs's Avatar
they are located
Lower left hand front corner of the engine, below the thermostat housing g100
Left hand rear corner of the engine, near the park neutral position switch g102
Old Mar 12, 2011 | 06:31 PM
lookat's Avatar
Default looking for a used abs and connector for 1995 seville sls 4.6
Basically the original ABS in our 1995 sedan Seville SLS shorted out.
The unit and connector seem to lie directly below the thermostat connection from the radiator, go figure. When replacing the lower radiator hose the ABS shorted out, my theory, water and electricity don't mix.
Old Mar 22, 2011 | 10:31 AM
99 sls's Avatar
Default ABS update
Turned out to be a bad pump and/or controller. I'm not spending $2500 to fix it. I can get an ispection sticker with the ABS light on. My only concern is that I would prefer not to start out in second gear all the time. Is there anything I can do to overide this? Thanks
Old Mar 23, 2011 | 08:05 PM
gmtechs's Avatar
abs should have no affect on what gear u start in.
there is a relay in the module if u replace that part u may be able to fix it
99STSGUY
Aluminum Block V8s
Jul 7, 2010 06:52 PM
HIRAM.T
Dec 20, 2009 07:16 PM
chaddemler1980
Jun 20, 2009 03:25 PM
marcus88
Nov 6, 2008 01:14 PM
ktowncaddy
Oct 8, 2007 06:29 PM
