95 cadillac deville ABS problem
I'm having a problem with the abs on 95 deville. When i press the brakes it scrubs, but not all the time. The abs light comes on after a couple minutes of riding. I checked the codes and i got t027 and t025 as the current codes. I also checked to see if the wheel speed sensors were plugged in and they were fine. Any suggestions are welcomed, thank you.
Also ran into this. Grinding of the breaks until suddenly it stops and the ABS light pops on as well as a "Traction Control OFF" indicator. My best guess is that it is a problem with one of the front hub assemblies, I have not yet put the time/money into getting it looked at. If anyone else has an idea, be great to hear.
well i had the same issue with my 99 seville the rear hub was bad. Had cadillac replace it and it cost me $500 or so. The rear hub is like 300 for the part. A few months later the other side went. This was not a daily driving car and I did not care if I had no traction control. Not telling you to do this but if you take the sensor and unplug it. Then shave away the wire coating and have the two wires touchit will void the code and make the error go away. Not saying to do this but it works.
Yeah, k. I checked into prices and the front hubs from an auto parts store were like $125ish. I wonder if it is a front? And if not, I wonder how much the rear hub would be from a non-Caddi dealer. I'll have to get it checked out, but I'll probably get em replaced soon. Thanks for the help Sneak.
