98 sts Fuse Blowing, Causes 5 engine codes????
I have a 1998 Cadi Seville sts, and I have 5 engine codes that appear after my ignition-1 fuse blows, i believe this is number 11 on the scimatic, it is a 10 amp fuse. The codes that appear are:
MAF Sensor circuit low frequency
1-2 shift solenoid circuit
2-3 shift solenoid electric
EVA \A Solenoid output circuit
TCCPWM SOlenoid Circuit
If anyone has any idea what could becausing this fuse to blow, or what they believe the problem is.
The only issues I see area slight idle shift, but thos is prob due to the fuse and the MAF problem...i have had service idle controol message appear 2 times but it goes away...I really need the help because Im a college kid without the money to just keep throwing money into it without know that ill fix the problem
UPDATE , found the short ,in my case its a misplaced loom holder that was pulling tight against the engine lift attachment , the metal had chafed through the loom and wire, took me 15 min to find ,
