1999 STS High Idle
Old Aug 30, 2007 | 09:27 AM
tigerdan's Avatar
Default 1999 STS High Idle
The car starts fine, then after a short period of time the idle starts creep up to +3000 rpm. The car has been towed to a Cadillac Dealership, and they can not find any codes. They have had the car for 2 days still no clue. I drove the car from Atlantic city to Philadelphia area just using the brake. The Dealership can't replicate the problem. The tow truck operator report the problem also.I don't trust the car until, they find something wrong. The car has 71,000 mile and well maintained. Please help.
Old Aug 30, 2007 | 09:38 AM
Default RE: 1999 STS High Idle
Ask your dealer about a idle senser control....Guys, these 99 sts's have them, right?
Old Sep 3, 2007 | 08:14 AM
Katzmans Caddy's Avatar
Seems obvious imo, the IAC as rickyd suggests.
Old Sep 3, 2007 | 10:05 AM
tigerdan's Avatar
Thanks, for the responses from Rickyd and Katzmans Caddy. The dealer called us Friday, and told us to pick up the car, they cannot find the problem. The dealer drove the car about 50 miles without the problem. We drove the car home and put it in the garage.
I asked the service manager about the IAC, and he said it checked out fine. Imo the dealer did not want to spend the time ($) to look for something that if not found, they would have a hard time billing. If it doesn't show up on a code in the computer its difficult for the mechanics to diagnose.
The car is in the garage till we decide on a replacement. Lucky for us it is not are only means of transportation.
Old Sep 3, 2007 | 12:47 PM
I think that replacing a 71,000 mile Cadillac just because it has a fast idle is a knee jerk reaction. I think that you can start by replacing the IAC, about $20, and cleaning the throttlebody,. MAF and IAC bore. I'd also look at the throttle cables and linkage and lubricate and check for any binding. Check all connections for sensors around the Throttle body and air boxtoo.
Old Sep 3, 2007 | 02:08 PM
tigerdan.... gee i don't think a caddy service store would pass up a fine opportunity to milk you on this one..... it sounds so simple...... however, if the car didn't act up for him, then he doesn't know what to r/r...... imo he did you a great justice in "not just changing parts" hit and miss.... Thank that s.a. and return to him when it reaccures...... hows your floor mats?
Old Sep 4, 2007 | 12:30 PM
tigerdan's Avatar
The floor mats are clean and on the floor where they should be. The Service Manager did not charge for any diagnostic time, which was good for me, but raises a question if a technician actually performed any checks. GM dealer mechanic's are paid flat rate if they spend any time on a customers car, the customer gets billed.
I spoke to an independent shop owner regarding the problem, he thought it might be a leak in the manifold gasket or intake. If it had an intermittent air leak would that show up as a code?
Old Sep 4, 2007 | 12:56 PM
hey tigerdan... is the car still acting up?........as far as your indepentent guy, i do believe you would hear the leak, if there is one....do you?that is a little behond me, so wait for one of the Tech to respond to that one.....as far as a code showing up..... imo, if a check engine light, or dic quote comes on then you'll most likly have a code to follow. the floor mats were a joke..sometimes they'll hang up your peddle....you got to know my humor....sorry.........good luck dude
ORIGINAL: tigerdan
Old Sep 14, 2007 | 10:08 AM
hows it goin????? new caddy, or did you fix the one you have????
Old Dec 3, 2008 | 02:26 PM
chicago02sts's Avatar
had the same problem change the plintum gaskets also called the intake gaskets there are 8 of them did that on my 02 sts did not know they were leaking till the starter went out.
boogcaddy
Dec 3, 2016 04:32 PM
xquizitone
Mar 22, 2010 10:17 PM
teddykan
Feb 3, 2009 06:40 PM
kobrien8
Nov 6, 2008 01:39 PM
daviddonovan4
Nov 17, 2007 02:23 AM
