93 BROUGHAM!!!LEAKING
Around my area every electricianis charging about $300 for that job.Maybe I should start by myself with the sensor and than cluster because I can get both for around $100.What do you think?unless is the wiring and cable.But at the same time I know I have both sensor an cluster good..Thank you for your help by the way
See if there codes stored first. Press off and temp up button. All segments on cluster should light up. If they don't you may need cluster. If code 24 comes up on a/c control head, check speed sensor speed sensor. No 24 speed sensor is ok. If parts are cheaper than diagnosis it maybe more cost effective to guess.
No code on ac unit..It shows -00-..Theres about 5 missing item on the cluster panel..So Im guessing is a bad cluster..How hard is it to reprogram a cluster again or is it only able to be done with dealer.Thanks
