1989 Brougham ECC Dead when Engine Running
Old Oct 16, 2018 | 12:30 PM
Noah Vail's Avatar
Default 1989 Brougham ECC Dead when Engine Running
I have an odd issue with my 1989 Brougham.
The ECC Control Panel operates fine with ignition ON and engine not running.
Start the car and the ECC Control Panel is dead and dark.
This used to happen on rare occasion. Last week it became permanent.
I've been thru the service manual.
The ECC Power Module seems okay, puts out 8v whether the engine is running or not.
The ECC Control Panel connector has 8v coming in whether the engine is running or not.
I'm not sure where to look next. Anyone have any ideas?
I'd sincerely appreciate any suggestions.
Old Oct 26, 2018 | 10:26 PM
quadcad's Avatar
Is the ECC the dash lights and warnings?
if so my 1996 dims when put in drive
part of the ambient light sensing circuit, annoying
the head lamp switch in 1996 I believe has the sensing circuitry
the schematic for electrical is incredible
I wonder if it can be unwired or rewired to ignore ambient light
Old Oct 30, 2018 | 12:57 PM
Noah Vail's Avatar
No. The ECC is the climate control panel. Thanks for the response tho.
UPDATE to OP: Issue is still intermittent.
The ECC always comes on when key is set to ON. When the key goes to START, the ECC goes out (dark, dead, whatever) - which I think it's supposed to do.
After the car is running a few seconds the ECC should come back on but most of the time it doesn't.
Nothing is visibly wrong (ie: melted) with the ECC control panel, programmer or the power module.
The 8v leads at the control panel & power module test good.
Any suggestions are welcome.
Old Jun 23, 2020 | 06:03 PM
Cadillac D's's Avatar
Here is a snap shot of the 1988 Brougham service manual. Should be the same for 1989. Looks like you need to jump pin 12 of circuit 155 to ground and see if you get a display or not. Since it's intermittent, it should be fixable
Paulforhelp
Jun 28, 2011 02:28 PM
Mommy26
Jun 25, 2011 11:34 AM
brushwolf
Dec 15, 2010 08:32 PM
richardo151
Jan 30, 2009 07:50 PM
Ghandi
Mar 16, 2007 04:29 PM
