99 deville coolant leak. Passenger side
Deville I bought started leaking coolant. I located where from. The metal pipe that the overflow tank line and heatercore hoses run to. Its rusted. Has pin holes in it. I see that it runs all the way around back side of the motor I tried patching it that's not gonna work how hard is or to change the whole line but. I'd like to hear If I couild cut some of it off and run new rubber hose to brass fittings. Or somthing cheaper. If possible any help is appreciated
Not bad for 400 finding it sitting needing headlight housings n grill n hood from deer radiator was fine no leaks outher than the one i spoke about
