97 DeVille hard to start when warm
Old Feb 16, 2008 | 04:05 PM
allenpinney's Avatar
Default 97 DeVille hard to start when warm
I have a 1997 DeVille, 130k miles. Runs great, pleanty of power. Starts fine when cold, cranks forever when warm. Will eventually start, but I mean it cranks for a while. 20 to 30 seconds if I let it go that long. Any suggestions. No codes. Also I used to have a full list of codes (about 23 pages long) that I got in a link from someone here last year. If anyone has that link I would appreciate it, I need to download and print them again.
Thanks,
Allen
Old Feb 16, 2008 | 07:03 PM
kmec's Avatar
Default RE: 97 DeVille hard to start when warm
Hi Allen, it could be a multitude of things but I would bet on the fuel pressure regulator. Remove the engine beauty cover and you will find it, top - right side. Round thing held by a funny clip and has two lines attached. Pull off the vacuum line and see if any gas comes out of the valve, even slight weepage indicates a bad valve so look close. Hold the vac line near the connection point & see if you can suck gas out. My guess is your going to find a small leak.
Great pictures here:
http://www.cadillacforums.com/forums...-pressure.html
Good Luck
Old Feb 16, 2008 | 07:09 PM
Kmec thanks, that was it. It was leaking, replaced it (75 bucks) plugs too (it needed them) now paked it after a short drive and waiting 30 min to see if it starts. Im sure that was it so thanks again. Hope I can return the favor someday.
Old Jun 27, 2008 | 07:36 PM
97Devile's Avatar
The information about the car starting problem is great. I have a question, How do you replace the fuel pressure regulator with out leaking gas? Thank in advance.
jack
Aug 20, 2010 03:22 PM
tonym2180
Feb 25, 2008 12:11 AM
malibuandryan
Oct 16, 2007 07:02 AM
bidness97
Mar 1, 2006 02:52 PM
bidness97
Nov 23, 2005 04:54 PM
