89 Deville with interior light problem
Old Jul 1, 2013 | 04:31 PM
Jyuma's Avatar
Default 89 Deville with interior light problem
Not a major problem but my interior lights will not go out unless I put the key in the ignition and turn it to the On position.
Here is a typical scenario... as soon as I push the door latch to open the driver’s side door the interior lights come on... (That’s good). If I immediately close the door the interior lights will stay on permanently... (That’s bad). The interior lights will stay on until the battery runs out of juice (several hours later).
However, if I open the door and then put the key in the ignition and turn it to the on position (no need to start, just on) and then remove the key and close the door, the interior lights go out and stay out until I open the door again.
There doesn't appear to be anything wrong with the switch in the door as all other functions controlled by that switch work as they should.
Any ideas?
91CBODY
Aug 14, 2012 02:30 PM
guyc
Nov 12, 2010 07:47 PM
Cadillac Al
Mar 10, 2009 08:58 AM
06 STS V
Jan 24, 2009 01:47 PM
Cadillac Al
Oct 12, 2008 10:30 AM
