2002deville check engine light help
Old Nov 8, 2008 | 04:12 PM
colbyjenner's Avatar
Default 2002deville check engine light help
Hi,
I just bought a 2002 deville and love it but the check engine light came on and i had autozone run the codes and this is what they got. PO420 Definition Catalyst efficiency low bank 1. Explanation: the oxygen sensors monitor the catalytic converters ability to store oxygen. Problen causes 1. Catalytic converter defective (failure possibly due to 2,3, or 4) 2. Engine misfire or running condition. 3. large vacuum leak. 4. Engine oil leakage into exhaust-valve guide seals, piston rings. I was wondering what you think i should do next. I have noticed no odd engine noises and it preforms great. Another code they got was PO741 and P1860 both related to the TCC Solenoid and TCC PWM Solenoid, I dont know if these are the same thing or not. How hard it it to replace this solenoid? The back windows will not work and i think they are off track, Is it hard on a deville to put them back on track? Thanks in advance for any help.
Thanks,
Colby
Old Nov 9, 2008 | 12:12 PM
Default RE: 2002deville check engine light help
i think the first thing id do is replace the oxygen sensor... clear the codes and see if they come back.
good luck
Old Nov 9, 2008 | 06:34 PM
Thanks for the help. What about replacing the tcc solinoid? And where would I find out how to change the oxygen censor? Autozone said they no longer clear codes so I am thinking about buying a scanner. What is a good on that isent to pricey?
Thanks,
Colby
Drama
Oct 6, 2020 09:45 PM
phantom
Sep 16, 2010 06:54 PM
99CaddyNH
Jul 17, 2008 06:36 PM
cosmictrucker
Feb 26, 2007 02:35 AM
