2002 deville base trunk will not open
Old Jan 17, 2026 | 03:02 PM
Jeffrey9871's Avatar
Angry 2002 deville base trunk will not open
Hey guys and gals,
I'm at my wits end concerning this beautiful low mileage Deville I purchased a while back. I've fixed 90% of the mechanical issues but am stuck with this seemingly simple problem. Any help is greatly appreciated!
Issue: Base model 02 Deville trunk will not open
Details:
-I have shorted the valet switch. So, valet mode is essentially always off. ie: gas tank does open. Trunk should as well.
-I have replaced the trunk relay. I do hear a click when I engage the trunk release.
-The key does turn normally when inserted
-I have put as much downward/upward force on trunk with key in open position as I'm able
-I think the internal manual trunk release is located in the very rear of trunk. There are multiple totes in the way. I initially thought I found it right behind the rear seat, but I just pulled out the speaker leads for the subwoofer
-I do not believe this car has separate ignition/trunk keys.
-Backseat opening is too small to fit through.
-I did completely remove the backseat thinking I could crawl back there, but access would be impossible without an angle grinder and an hour of cutting. Now that I think about it, isn't out of the question....
Theory
-I think this vehicle was towed by police based on all the jail/prison paperwork I found in the trunk(found through small opening in backseat). I wonder if after their search, they slammed some clothing or something in the locking mechanism.
Possible solutions I haven't tried:
-Locate the solenoid leads and send 12v(maybe a little more). There are a lot of wires back there. I did try this but failed to identify which ones.
-Drill a hole behind license plate and pry the locking mechanism. This is a bit more invasive than I'd like but if this is the only option, I'm okay with it if I know where to drill.
Bottom line:
-I don't know what the heck is in that trunk. Based on the do***ents I found, this dude could have been a bad person, and I don't want to drive around with hidden crimes.
Thanks for reading.
Muscleboy
Jan 26, 2020 08:50 PM
c.camp450
Jun 21, 2010 03:28 PM
GASiron
Jul 2, 2009 03:22 PM
89whitefleet
Sep 19, 2008 07:41 PM
vweater2001
Jun 29, 2006 03:13 AM
