2001, Ticking noise from dash area
Old Oct 7, 2006 | 09:23 PM
nkohrn's Avatar
Default 2001, Ticking noise from dash area
I just purchased a 2001 Deville and when I start the car, a ticking noise eminates from the driver's side dash area. It goes for a few moments, stops, then ticks again for 2 or 3 ticks then stops for the rest of the time the car is on. It does not stop when I turn the a/c off or is adjusted nor any other item (or so it seems). I am curious if anyone is familiar with this issue. Or if a TSB might have been written on this issue.
Old Oct 8, 2006 | 10:49 AM
FLCaddytech's Avatar
Default RE: 2001, Ticking noise from dash area
I believe you will find the mode door actuator on the drivers side is starting to strip out.
Old Dec 30, 2006 | 12:45 AM
toterboy's Avatar
What became of your Ticking problem? I also have the same thing going on in my 2001 DTS. Am very interested if or how you solved problem. I havent found any part source that covers such a part. Any advice would be greatly apprecieated.
Caddy Jay
Apr 8, 2011 11:32 PM
reginaldsidney
Aluminum Block V8s
Jul 23, 2009 03:18 PM
thejohnson
Jun 10, 2009 11:31 AM
stsawd
Mar 6, 2008 08:32 AM
toterboy
Dec 26, 2006 11:49 PM
