1997 Deville antilock & brake light on why...
Hi all,
I just bought a 1997 Deville .Took it for a test drive and the brakes were very very bad but no antilock & brake light was on.
I had the dealership fix the brakes before taking possession.Supposedly they cut all rotors replaced all pads.But then the antilock & brake light was on immediately afterwards.Supposedly they reset the computer but no luck.
What could they of done for this to happen? Is there a wire or a sensor etc they could of messed up...
They supposed to order a sensor (don't know what) but I am not holding my breath as They don't have the car anymore.
The brakes feel fine except for the lights are on.
I did have them sign saying that they will fix whatever is wrong with the brakes but you know how that is after they have your money.
So I wanted to try to see if it was something I could do by myself if they don't follow through.
Thanks
Michael
Thanks
Michael
I notice on my 91 deville that my ABS light would stay off when i rest untill i turned teh front wheels so in my case i norwed it down to my front wheels and then jack up teh car and had my friend look at the light after a reset it to off and I wigled the wire 1 at a time till the ABS light came on.
So to finsh up my right front wheel sensor was out on my car replace it its fine now wheel senors cost $50 - $80
i went to the junck yard i lucked out $5 LOL
Well, before you do anything it's a good idea to check the codes first. You can do it by pressing and holding the OFF and passenger warmer buttons at the same time for about 5 seconds untill all of the LED displays light up. Post the codes here and someone will tell you what they mean.
I think the most likey thing is that they didn't put the brake pad sensor in right.
jono6406
Feb 13, 2008 12:13 PM
agustinsoldier
Nov 28, 2007 07:25 PM
Michaelrj9
Jun 3, 2007 09:52 PM
