Why do the 22s on my 01 deville rub?? help ! !
Old Sep 5, 2007 | 03:59 PM
agustinsoldier's Avatar
Default Why do the 22s on my 01 deville rub?? help ! !
i have an 01 deville and just bought 22s (255/30/22) but they rub really bad
does any one know if you have to do any mods to the car to stop therubbing ????
any info would help thanks
Old Sep 7, 2007 | 03:29 PM
Katzmans Caddy's Avatar
Default RE: Why do the 22s on my 01 deville rub?? help ! !
Yes , you need to do some modifications to stop then tires from rubbing, but you need to explain better. Are they bottoming out, front or rear, on turns, over bumps etc....
Old Sep 8, 2007 | 08:58 AM
like Katz said.
also, a picture would do wonders.
Old Sep 23, 2007 | 03:17 PM
jd3772001's Avatar
1. SHOULDNT HAVE PUT ANYTHING BIGGER THAN 20" ON IT.
2. THEY MAKE A 245-30-22 TIRE
3. THEY MAKE 22X8.5 WHEELS...IF ANY WIDER RUBBING HAPPENS.
4. CUT THE PARTS OF THE WHEEL WELL OUT OR REMOVE THE WHOLE LINER.
Old Oct 21, 2007 | 01:31 AM
rblimas's Avatar
ORIGINAL: jd3772001
sounds about right, minus #1...
Old Nov 26, 2007 | 07:19 AM
Alrukin's Avatar
What kind of ride do you get with 22s? Do you have to check your speed?
Old Nov 28, 2007 | 07:25 PM
gyalteaser's Avatar
my deville has 22" on it and i have no rubbing issues ...i am running a 245/30/22....rims are 22x8.5....
and to answer Alrukin's question
i really didnt lose that much of ride quality....you feel the road more in the sterring wheel though..
sevilleguy9701
Jun 7, 2011 02:42 PM
Steve368Deville
Aug 2, 2010 05:51 AM
haltomguy
Dec 11, 2009 01:11 PM
brolajit
Feb 19, 2008 08:56 PM
Michaelrj9
Nov 30, 2006 04:59 PM
