DIC, Traction Control, Antilock issues!
Old Sep 29, 2008 | 11:19 AM
serpico's Avatar
Default DIC, Traction Control, Antilock issues!
I just recently bought a 95 STS and love the car. There are a few things that I need help with. The information center, dic and A/C control are blank. The controls for the A/C work fine but can't set the temp. I have ordered a replacement cluster and hope that will fix that problem but I have a antilock brake warning on and think that I have a traction control issue. The car seems to take off in second gear which through reading on this forum seems to indicate T/C issues. I am not sure where the control box is even to replace it. I pulled the shelf down in the trunk and found what looks like a missing control box for something. If you look into the trunk there is a empty spot on the deck with a connector hanging loose. Is this possible? I cant get codes because I have no dic. Please help!
Thanks,
Scott
Old Sep 29, 2008 | 03:11 PM
Default RE: DIC, Traction Control, Antilock issues!
ORIGINAL: serpico
Thanks,
Scott
hopefully someone will chime in and help with details.
in the meantime, may i suggest that you chase a FACTORY SERVICE MANUAL?
you seem at easy with tools and car things.
these folks may have one and priced right.
http://stores.ebay.com/Factory-Shop-Manuals
rushpoint
Mar 16, 2012 09:42 PM
Adrian_407
Jun 21, 2011 04:08 PM
Adrian_407
Jun 18, 2011 11:53 AM
TDL
Oct 24, 2007 05:05 PM
Michaelrj9
Nov 30, 2006 04:59 PM
