DIC, Traction Control, Antilock issues!
I just recently bought a 95 STS and love the car. There are a few things that I need help with. The information center, dic and A/C control are blank. The controls for the A/C work fine but can't set the temp. I have ordered a replacement cluster and hope that will fix that problem but I have a antilock brake warning on and think that I have a traction control issue. The car seems to take off in second gear which through reading on this forum seems to indicate T/C issues. I am not sure where the control box is even to replace it. I pulled the shelf down in the trunk and found what looks like a missing control box for something. If you look into the trunk there is a empty spot on the deck with a connector hanging loose. Is this possible? I cant get codes because I have no dic. Please help!
Thanks, Scott |
RE: DIC, Traction Control, Antilock issues!
ORIGINAL: serpico I just recently bought a 95 STS and love the car. There are a few things that I need help with. The information center, dic and A/C control are blank. The controls for the A/C work fine but can't set the temp. I have ordered a replacement cluster and hope that will fix that problem but I have a antilock brake warning on and think that I have a traction control issue. The car seems to take off in second gear which through reading on this forum seems to indicate T/C issues. I am not sure where the control box is even to replace it. I pulled the shelf down in the trunk and found what looks like a missing control box for something. If you look into the trunk there is a empty spot on the deck with a connector hanging loose. Is this possible? I cant get codes because I have no dic. Please help! Thanks, Scott in the meantime, may i suggest that you chase a FACTORY SERVICE MANUAL? you seem at easy with tools and car things. these folks may have one and priced right. http://stores.ebay.com/Factory-Shop-Manuals . |
